MARS Error "Oracle and Linux"
To all MARS Guru,
I'm a newby to this MARS, and we have MARS 25.
I'm following the initial config guide and I was able to change the default password, interface IP and gateway.
But when I found out that my IP and gateway are both wrong, I tried to change it but no success.
I rebooted the MARS using reboot command but still the same result. Using the command "gateway" here's the error:
Program aborted due to: ORA-01034: ORACLE not available
ORA-27101: shared memory realm does not exist
Linux Error: 2: No such file or directory
Can anyone please give advise what needs to be done?
Brian
rajett Mon, 02/16/2009 - 08:32
  • Cisco Employee,
Hi Brian,
Reboot the appliance and try again. If not successful then try it with the ethernet cables unplugged.
If that's not it then you may need to reimage it.
RJ
