IP SLA OID
My requirement is to check for one-way latency of my link. I have configured ip sla "icmp echo" option for that
Configuration
ip sla 200
icmp-echo 10.97.1.11 source-interface GigabitEthernet0/1
timeout 20
threshold 20
frequency 15
ip sla reaction-configuration 200 react rtt threshold-value 20 10 threshold-type
immediate action-type trapAndTrigger
ip sla schedule 200 life forever start-time now
snmp-server enable traps ipsla
snmp-server host 10.50.2.151 <string> ipsla
I am using HPOV as NNM. I need to view the trap I am receiving from the router. Can I know what oid values I need to have in my HPOV for IP sla.
Thanks and regards
SAT
Joe Clarke Tue, 02/17/2009 - 08:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you must load this MIB into NNM. That will import all of the traps and OIDs so you can translate the varbinds from the IP SLA notification into human-readable object names.
If you have never loaded Cisco MIBs into NNM before, you should first read this document as there are prerequisite steps to follow:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800b4cee.shtml
Hi clarke,
Thanks for the response and the reference document. I was able to download the " CISCO-RTTMON-MIB" and tried to load in my HPOV. I am getting an error " [CISCO-RTTMON-MIB] - Line 6235: Error defining object: found 'nReactConnectionEnable' "
I am also attaching the snapshot of the error message.
Am I missing something or do I have to edit the file which I downloaded.
Thanks and Regards
SAT
