Problem with NetConfig Adhoc task
Answered Question
Feb 16th, 2009
I have RME4.1.1. I can't open Adhoc>Add Instance... The Windwos too small (s. Attachment).
Correct Answer by Joe Clarke about 8 years 4 months ago
That's what I thought. This is a bug I found when doing ZFS testing. Unfortunately, since LMS 3.0.1 isn't officially supported on ZFS, I cannot provide you a patch. I do, however, have a patch for LMS 3.1.
There is a workaround, though. Copy /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs to some other file system. Then delete /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs. Then, copy the directory back from the other file system. Restart dmgtd, and you should be able to use Netconfig.
For the record, the bug is CSCsr13209.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 02/16/2009 - 10:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
First, it looks like your locale is not US English. Set your client locale to US English, then try configuring IE to open new windows as new windows (instead of tabs). If that doesn't work, try Firefox 2 to see if this is a browser issue. Also, on what platform is the server running?
IGOR SPANZ Tue, 02/17/2009 - 00:24
I have the same problem with the US English client with IE (s. Attach2.jpg) configuring to open new windows as new windows (instead of tabs)and Firefox.
Server running on Solaris platform.
Joe Clarke Tue, 02/17/2009 - 00:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Do you have LMS installed on ZFS?
Correct Answer
Joe Clarke Tue, 02/17/2009 - 00:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
IGOR SPANZ Tue, 02/17/2009 - 01:37
Thank you, although we have the LMS 3.0.1, this Workaround has helped
