AP 1000 series in WCS 5.2.125.0
Feb 16th, 2009
I've upgraded WCS 5.2.110.0 to 5.2.125.0, it solved guest management problem but now I see all APs 1010 are down. Is this another bug ?
gudmundurk Mon, 02/16/2009 - 08:01
Were these access points working before on version 5.* ?
According to the release notes from Cisco:
"Note Controller software release 5.0.148.0 or later is not compatible with Cisco Aironet 1000 series access points."
mwaliczek Mon, 02/16/2009 - 16:00
Controllers have 4.2 software, with WCS 5.2.110.0 everything worked fine, some problem is with 5.2.125.0 :/
regards
Marcin
ericgarnel Mon, 02/16/2009 - 08:41
hmmm.... the vxworks based APs were dropped with the 5.x train.
a.hallberg Thu, 02/26/2009 - 09:16
Hi, got the same issue like you when uppgrading to 5.2.125.0 and yes, it is a bug (CSCsx65413) Cisco now have a fix for this in 5.2.130.0.
Trending Topics - Security & Network
