Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1926049members
1237407discussions
Community Activity
IPSec VPN Tunnel Lan-to-Lan decrypt count zero
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 1 Views
  • 0 replies
IE3400 Heavy Duty Series Uplink Network Configuration
I have a new project that we are considering to use IE3400 Heavy Duty series switches to support the remote field sites. I have few design questions:Our network architecture includes a main hub site with core switches (standard Cat-9500 stack) and 22...
ezisaac by Level 1
  • 71 Views
  • 1 replies
Cisco ISE - Container Storage Space Issue
Hello,Our Cisco ISE HA does suffer from some performance issue and by checking the logs, it became obvious that were are dealing with a space issue: Sending SNMPv2 trap for partition /opt/podman/containers/storage/overlay/...merged which reaches the ...
netmart2 by Level 1
  • 122 Views
  • 2 replies
My Cisco Nexus Swith 6001 is stuck in bash mode
My Cisco Nexus Swith 6001 is stuck in bash mode and giving below error.system is coming up.....please wait.......This issue happens after power outage happened. We have reboot switch many times and used multiple username/passwords but its not appeari...
cisco 4507R ARP问题
核心交换机vlanif是客户端网关,客户端无法获取网关IP,手动添加arp可以和网关通信,在核心交换机上有客户端的mac和arp,并且接口信息正确,我在核心上clear下arp信息,客户端就自己能获取网关arp ,不明白,请帮忙分析下
cisco 4507R ARP Issues
The VLANIF of the core switch acts as the gateway for client. The Client is unable to obtain the gateway IP, but by manually adding ARP, it can communicate with the gateway. The core switch has the correct MAC and ARP information for the client, a...
Translator by Community Manager
  • 40 Views
  • 1 replies
Recommendation Software ISE
Hi EveryoneOur client for ISE software still uses version 2.6 with pach 10,We will upgrade the software to 3.1 with patch 8, please provide a recommendation link from CiscoI'm afraid that if I downloaded it wrong it would have fatal consequencesThank...
Iridium Satellite phone integration with Cisco PABX
HI, we have project requirement to integrate the Iridium Satellite phone integration with Cisco PABX to make a calls in case of emergency. Can you please suggest, what can we achieved with this interface.1) can we make calls on any number at cisco PA...
inhamit by Level 1
  • 67 Views
  • 2 replies
ASA9.5(1)以降: 管理通信用のRouting Tableの分離について
はじめにManagement Interfaceの指定と Routing Tableの確認管理通信(Management Traffic)とはManagement-access設定を併用時の注意点その他 注意事項参考情報   はじめに ASAバージョン 9.4までは、1つの Global Routing Tableを共用していました。 ASAバージョン 9.5(1)より、管理通信用と その他通信用のRouting Tableを、分けて管理するよう変わりました。 Management I...
MTLS does not take effect
My expressway version is X12.6.1,Mutual TLS mode is on, both the CA certificate and the server certificate have been imported, then configured an dns zone with TLS verify mode is on ,also have TLS verify subject name, When I initiated the call, I fou...
XML Cisco IP Phone Services with Jabber Android
Does anyone have experience using XML Cisco IP Phone Services with a Jabber/Webex client on Android? It makes sense that notifications / button presses to a native app on Android is not going to work.Do the old CUCM XML based IP Phone Services work w...
Forrest by Level 1
  • 51 Views
  • 0 replies
Webex Calling - 通話中の Webex アプリで着信通知が表示されない事象について
2024 年 4 月 16 日 (初版) TAC SR Collection主な問題 Windows 版の Webex アプリで通話中に別の通話がかかってきた際に、着信通知(ポップアップ)が表示されないという問題が報告されています。 原因 「設定」メニュー内の「通知」セクションにおける「通話」の設定で、「常に通知をミュート」もしくは「ミーティング中、または通話中のみ通知をミュート」が選択されていることに起因している可能性があります。 解決策 「設定」メニュー内の「通知」セクションにおける「...
SSID not discoverable by laptop in Packet Tracer
We have configured two Lightweight Access Points using a 3504 WLC. Both access points are connected to the WLC, and have been assigned IP addresses through DHCP from the WLC. Both also state they are providing the WLAN we created. Authentication for ...
cmonte0247 by Community Member
  • 40 Views
  • 0 replies
UCS C Utilities: Bug Trend 2024年1-3月
UCS C Utilities に関する不具合で、1ヶ月間ごとに関連 SR の報告が多かったもの Best 5 です。 あくまで、TAC Service Request (SR) として問い合わせのあったもので、Partner や User 自身で解決したものは含まれていないため、実際に発生した件数の Ranking ではないのでご注意ください。   2024年1月 (対象になるものがありませんでした)   2024年2月 BugIDTitleCSCwe86015Standalone Rack...
fenglliu by Cisco Employee
  • 33 Views
  • 0 replies
