Jaime Valencia Mon, 02/16/2009 - 07:16
  • Cisco Employee,
  • Hall of Fame,
    2011
the corporate directory doesn't ask PWD in any version.
in 6.X you need it for PAB and SD but not for corporate directory
java
if this helps, please rate
Brian Carscadden Mon, 02/16/2009 - 07:56
Thanks ... but can you tell me the direct link to the directory? The one I pointed out in my previous post doesn't work.
Kenneth Mohammed Mon, 02/16/2009 - 08:09
  • Silver, 250 points or more
Hey Java,
I tried that on my version of 6.x and it doesnt work..I get the following:
HTTP Status 404 - /ccmip/xmldirectory.jsp
type Status report
message /ccmip/xmldirectory.jsp
description The requested resource (/ccmip/xmldirectory.jsp) is not available.
Apache Tomcat/5.5.17
Please disregard above post.
Jaime Valencia Mon, 02/16/2009 - 08:18
  • Cisco Employee,
  • Hall of Fame,
    2011
i assume you configured this under URL directories and are not trying to access this thru a browser right?????
java
Brian Carscadden Mon, 02/16/2009 - 08:22
Sorry, no ... my original question was about the direct web link, for a web browser.
Brian Carscadden Mon, 02/16/2009 - 08:14
Perhaps you're confused ... I'm referring to accessing the Corporate Directory from a web browser, not the IP Phone. In Callmanager 4.x, the link was "http://x.x.x.x/ccmuser/directory.asp". I'm looking for the equivalent in Communications Manager 6.x.
Brian
nelcnetworks Fri, 02/20/2009 - 02:30
I also am looking for this facility. One way would be to setup a generic user for the login, but it would be preferable to be able to get direct web access.
