Unable to establish calls between CME and CCM.
Feb 16th, 2009
Hi All,
I have a lab setup having CME and CCM. IP Phones are registered to both the Call agents and have registered CME as H323 gateway in CCM. I am able to call from IP phone registered with CCM to CME but not vice versa. Any idea why so? IP Phone on CME's number is 64058XXX and IP Phone on CCM is 6XXX
I have attached running config of CME below.
GW-2#sh run
Building configuration...
Current configuration : 2710 bytes
version 12.4
hostname GW-2
boot-start-marker
boot-end-marker
!card type command needed for slot 1
no logging console
enable password cisco
no aaa new-model
resource policy
no network-clock-participate slot 1
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.50.1 10.10.50.10
ip dhcp pool CME
network 10.10.50.0 255.255.255.0
default-router 10.10.50.1
option 150 ip 10.10.50.1
voice-card 0
no dspfarm
voice-card 1
no dspfarm
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.4
encapsulation dot1Q 4
ip address 10.10.20.1 255.255.255.0
no snmp trap link-status
interface GigabitEthernet0/0.5
encapsulation dot1Q 5
ip address 10.10.40.1 255.255.255.0
interface GigabitEthernet0/0.6
encapsulation dot1Q 6
ip address 10.10.50.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 192.168.1.2 255.255.255.252
no fair-queue
clock rate 125000
interface Serial0/0/1
no ip address
shutdown
clock rate 125000
interface Serial0/1/0
ip address 192.168.1.5 255.255.255.252
ip route 10.10.10.0 255.255.255.0 192.168.1.1
ip route 10.10.10.0 255.255.255.0 192.168.1.6 200
ip route 10.10.30.0 255.255.255.0 192.168.1.1
ip route 10.10.30.0 255.255.255.0 192.168.1.6 200
ip http server
no ip http secure-server
tftp-server flash:/PHONE/7940-7960/P00308000500.bin alias P00308000500.bin
tftp-server flash:/PHONE/7940-7960/P00308000500.loads alias P00308000500.loads
tftp-server flash:/PHONE/7940-7960/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/PHONE/7940-7960/P00308000500.sbn alias P00308000500.sbn
control-plane
dial-peer voice 1 voip
destination-pattern 6...
session target ipv4:10.10.20.100
telephony-service
load 7960-7940 P00308000500
max-ephones 52
max-dn 192
ip source-address 10.10.50.1 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
ephone-dn 1 dual-line
number 8000 secondary 64058000
ephone-dn 2 dual-line
number 8001 secondary 64058001
ephone-dn 3 dual-line
number 8002 secondary 64058002
ephone-dn 4 dual-line
number 8003 secondary 64058003
ephone 1
mac-address 000D.654B.8D36
type 7960
button 1:1 2:2
ephone 2
mac-address 001D.728E.D42C
type CIPC
button 1:3 2:4
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
Mangesh A. Bhende
Kenneth Mohammed Mon, 02/16/2009 - 07:23
  • Silver, 250 points or more
Hello Mangesh,
In CCM, under the H323 gateway configuration, check the calling search space for incoming calls. Be sure that this calling search space has visibility to whatver partition the CCM phones 6XXX extensions reside.
Hope that helped, if so please rate.
bhende.mangesh Sun, 02/22/2009 - 21:59
I have added h323-gateway voip bind srcaddr ip-address command, under interface configuration mode and the problem got resolved.
Mangesh A. Bhende
