ASA 5505 Slow LAN Response
Feb 16th, 2009
Installed ASA5505 in branch office. Have l2l VPN between it and HQ. Office is 1 server (W2k), 3 users, 1 printer.
Since connecting LAN to ASA users complaining of slow response times. When pinging from server to devices, average response is 20-30ms.
Ivan Martinon Mon, 02/16/2009 - 07:27
  • Cisco Employee,
Is this through the Lan to Lan? If this is from Lan to Lan then ping from VPN end point to VPN endpoint, what is the rate? if this is from within the LAN have you check if your switch has no conflict on MAC addresses?
benharned Mon, 02/16/2009 - 07:30
This is from within, on the internal LAN. No dup. MAC in the ARP table.
Ivan Martinon Mon, 02/16/2009 - 07:31
  • Cisco Employee,
go ahead and do a "show run all sysopt" on your ASA and post it here please
benharned Mon, 02/16/2009 - 07:32
Result of the command: "sh run all sysop"
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
sysopt connection permit-vpn
no sysopt connection reclassify-vpn
no sysopt connection preserve-vpn-flows
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
no sysopt noproxyarp inside
no sysopt noproxyarp outside
Ivan Martinon Mon, 02/16/2009 - 07:44
  • Cisco Employee,
Well proxy arp is disabled, usually these issues might occur by it. Have you cleared the arp of the devices that might need a refresh? I really can't think on why your ASA will cause issues for traffic that does not even get to it.
benharned Mon, 02/16/2009 - 07:47
Naiveté alert: how do you do that? Are you talking just network equip. arp, or do PC's have arp that need clearing?
The ASA is the only switch in the network.
