International escape character "+"
Feb 16th, 2009
Hi all,
I know that we can use a plus sign preceded by a backslash, that is, \+, for indicate the using of the international escape character in CUCM 7.
is there any way to use that with CCM 4.2?
Thanks in advance
Overall Rating: 4.5 (2 ratings)
Jaime Valencia Mon, 02/16/2009 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    2011
the + capability in CUCM is introduced in 7.X, no previous version had this
java
if this helps, please rate
carlosjlopez Mon, 02/16/2009 - 08:12
thanks javalenc for your fast answer.
do you know if it's possible than Cisco offer an update for previous version of CCM?
Jaime Valencia Mon, 02/16/2009 - 08:27
  • Cisco Employee,
  • Hall of Fame,
    2011
no, this will only be on 7.X and onwards
java
