We have a couple 5540s (running version 8.0(4)) in vpn loadbalancing mode. Frequently we get the following log messages:
%ASA-3-713128: Connection attempt to VCPIP redirected to VCA peer x.x.x.x via load balancing
In the system log messages manual it says:
Explanation: This message appears when a connection attempt has been made to the VCPIP and has been redirected to a less loaded peer using load balancing.
Recommended Action: None required.
My question is why this message is logged at level 3 (error)? As far as I understand this is normal behaviour when the master redirects a VPN connection to one of the less loaded slaves.
We could set the log-level ourselves (using logging message 713128 level informational), but first I wanted to make sure that this message does not indicate an error.
It would be great if someone could clarify this!
Best regards,
Harry
