What's the command "PLATFORM" doing?
Feb 16th, 2009
Hi ALL !!!
I have some proplems with "High CPU Utilization" on the Cisco ME-3400-12.
And I heard the command "platform" can change behavior of switch, but I couldn't find nothin about it.
Please give me somethin links or hints obout this command !!!
Giuseppe Larosa Mon, 02/16/2009 - 09:17
  • Hall of Fame,
    Founding Member
Hello Oleg,
multilayer switches can change behaviour depending on how they allocate the Tcam tables.
use the following to verify the sdm in use
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_46_se/configuration/guide/swsdm.html
if you are using layer-2 sdm routing is done via SW and this loads the cpu.
After changing the sdm mode you need to reload the swith to make the change effective.
note:
I didn't find the platform command in 12.2(46)SE command reference so I think you are meaning the sdm method
Hope to help
Giuseppe
Oleg Gnedykh Tue, 02/17/2009 - 04:20
Hi!
Thank you very much for your answer!
It was realy SDM configuration.
PS:However, the command "platform" really exists.
Cisco(config)#platform ?
ip platform ip specific config commands
IOS 12.2(46)SE
