VOIP dial peer - redundancy not working
Feb 16th, 2009
I have a problem with two VOIP dial peers in the config below on a CUBE.
When calls come into the CUBE they are sent to CUCM via dial peer 200 and 210. DP200 is preference 1 so is always chosen. DP210 is preference 2 so this is a redundant route to another CUCM.
Here is the config:-
dial-peer voice 300 voip
description ** incoming dial peer **
rtp payload-type nse 99
rtp payload-type nte 100
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
dial-peer voice 400 voip
description ** SIP Trunk from SP**
destination-pattern 9T
session target ipv4:x.x.x.x
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
dial-peer voice 200 voip
description ** outgoing call to CUCM **
preference 1
destination-pattern 44T
monitor probe icmp-ping 10.25.0.199
session target ipv4:10.25.0.199
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
dial-peer voice 210 voip
preference 2
monitor probe icmp-ping 10.25.0.11
session target ipv4:10.25.0.11
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
The problem is that when the CUCM on DP200 is not reacheable, calls to not pass over to DP210.
Here is the output of a show dial-peer voice summary:
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
PORT
300 voip up up 0 syst
400 voip up up 9T 0 syst ipv4:x.x.x.x
200 voip up up 44T 1 syst ipv4:10.25.0.199
210 voip up up 44T 2 syst ipv4:10.25.0.11
I though that the monitor probe icmp command would detect that the DP200 CUCM is down but it doesn't seem to detect this? (Incidentially to test this I have used a fake IP address in DP200 - it doesn't exist anywhere on my network and so is obviously down).
Any ideas?
Randall Poteat Thu, 08/25/2011 - 06:24
Hi Yuko.
What was the fix in this problem?  I am running into the same issue.
Randy
