1522 Antennas configuration
Feb 16th, 2009
I have a doubt with the 1522 Access Point antennas configurations. The document show that there are two options for antenna configuration based on how the access point is mounted.
----------Cable strand-----Pole Mount
Antenna
Port
1---------2.4Ghz------------5Ghz
2---------5Ghz--------------no
3---------2.4Ghz----------- 2.4Ghz
4---------no----------------2.4Ghz
5---------no----------------no
6---------no----------------2.4Ghz
I don't understanding well.
. The antenna port 1, work with 2.4 and/or 5Ghz?
. If the Access Point is a RAP, it's work as cable strand? And if is a MAP it's work as a Pole Mount?
. My company bought a 1522 access point, and the access point is labeled this way: antenna port 1 = 5Ghz
antennas port 3,4 and 6 = 2.4Ghz
What is the factor, for decision if I use Cable strand or Pole Mount ?
obs: My Access Point will work as RAP.
thanks !
Claudio
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
