02-16-2009 08:50 AM - edited 03-13-2019 06:05 PM
I was wondering if there is a way to know the login / logout times of different users of extension mobility, maybe directly at the database or within some log at the CUCM. Does anyone know it? It's for a version 4.2, and for a version 6.1, so the procedure should be different.
Thanks in advance,
Solved! Go to Solution.
02-16-2009 09:13 AM
only using the EM traces
there is no reporting on that
java
if this helps, please rate
02-16-2009 09:13 AM
java
02-16-2009 01:59 PM
there is an Extension Mobility API, you can use UserQuery or DeviceQuery but I am not sure what details are returned...
