Jon Marshall Mon, 02/16/2009 - 10:10
Denis
Could you give a few more details.
You can use transparent mode where you have 2 vlans with one IP but by the sounds of it this is not what you want.
Are you asking if the ASA can support IRB (Intergrated Routing/Bridging) where 2 interfaces on your ASA are in the same vlan and share an IP address ?
Jon
Jon Marshall Mon, 02/16/2009 - 11:40
Denis
I'm not aware of the ASA supporting the likes of IRB but then i have never found the need to configure it so i'm not 100% certain on that. I have had a quick look at the configuration docs and couldn't find anything other than transparent mode which is slightly different ie. you bridge together 2 vlans.
Unfortunately i don't have access to an ASA to test but i don't think this is supported.
Jon
denaumcisco Mon, 02/16/2009 - 11:55
Well, I need to link 2 computers into the ASA using necessarily 2 ASA's interfaces.
and I need to put the same IP address on both interfaces, because the computers have the same configuration
Anybody?
denaumcisco Mon, 02/16/2009 - 12:33
I need to do a vpn between two ASA 5520 with the basic IOS, can I do it?
denaumcisco Wed, 02/18/2009 - 15:03
Mike,
Do you have a configuration for me to do a vpn between 2 ASA 5520?
I tried use some commands from the guide that u sent to me , but without sucess
denaumcisco Thu, 02/19/2009 - 03:13
Anybody has a configuration for me to do a vpn between 2 ASA 5520?
I tried use some commands from the guide isakmp/ipsec , but without sucess
And a solution to a backup route, I found the command "track" on the internet, but didnt work on 5520
thanks
denaumcisco Thu, 02/19/2009 - 03:24
Here is the vpn configuration and the results
crypto isakmp policy 10 hash md5
crypto isakmp policy 10 authentication pre-share
crypto isakmp enable outside
crypto map mymap 10 match address 100
access-list 100 permit ip 172.16.3.0 255.255.255.0 172.16.1.0 255.255.255.0
crypto ipsec transform-set myset esp-des esp-hd5-hmac
crypto map mymap 10 set peer 10.22.12.22
crypto map mymap 10 set transform-set myset
crypto map mymap interface outside
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 10.12.28.5
Type : user Role : initiator
Rekey : no State : MM_WAIT_MSG4
robertson.michael Thu, 03/12/2009 - 14:53
Hi Dennis,
Can you post the configurations on both sides of tunnel? Many of the settings much match. Here is an example that should at least bring the tunnel up:
ASA1:
crypto isakmp policy 10 encryption des
crypto isakmp policy 10 group 2
crypto isakmp policy 10 lifetime 86400
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap 10 set pfs
ASA2:
access-list 100 permit ip 172.16.1.0 255.255.255.0 172.16.3.0 255.255.255.0
crypto map mymap 10 set peer 10.22.12.21
As I mentioned, if you are still having trouble, please post your existing configs that exist on each side of the tunnel.
Hope that helps.
-Mike
