DDI
Feb 16th, 2009
Wer can I found information about how to configurin DID on the following scenary
Callmanager ver
H232 voice Gateway - E1 PRI
PTSN num - 2602300
Phone ext num 3xx
I want that when peopel call 2603301 it go to ext 301 and so
Jaime Valencia Mon, 02/16/2009 - 11:05
  • Cisco Employee,
  • Hall of Fame,
    2011
configure the GW as usual
on CCM significant digits set to 3
DNs using 3 digits
java
if this helps, please rate
Afragoso2009 Mon, 02/16/2009 - 12:33
Its already done .But in wath concerning the VOice Gateway?
Before , I have a plar connection , but all the call came just to one Phone
Jaime Valencia Mon, 02/16/2009 - 13:45
  • Cisco Employee,
  • Hall of Fame,
    2011
voip dial peer using the digits you expect to receive and send it to CUCM with session-target command
java
Afragoso2009 Thu, 04/02/2009 - 02:18
Hi Adrian
I am using the foolowing dial-peer
dial-peer voice 300 voip
preference 4
destination-pattern .
session target ipv4:172.19.0.253
dtmf-relay h245-alphanumeric
codec transparent
But any all the ext ( from 301 to 399 ) are receiving the call direct fom outside.How can I block some ext to not receive a call ?
