Downgrade Software Controller from 5.2.157 to 4.1.192.35M.
Feb 16th, 2009
Hi for all,
I need to make a downgrade in 4402 WLC from 5.2.157, that has some bugs, to 4.1.192.35M.
In the release note 4.1.192.35M shows:
"A downgrade to mesh releases 4.1.190.5, 4.1.191.24M, and 4.1.192.35M from non-mesh release 4.2 is not supported".
I want know what sequence of release downgrade I need to make this.
thanks !
Claudio
GregL Mon, 02/16/2009 - 10:56
Claudio do you need mesh or not. If I remeber right the 5.2 code allows you to do mesh and standard LWAPP on one controller prior version of code 5.1 and back dont allow you to do both on the same controller if you dont need mesh I would recommend going back to 4.2.176 code. Please let me know more.
rezende.c Mon, 02/16/2009 - 11:09
Hi Greg,
Yes, I need mesh. My Controller worked with only LWAPP standard, but now I will install new Access Point 1522 and 1240 in mesh mode. I installed the version 5.2 and some bugs happened. So I make the downgrade to 4.2.176.
The 4.1.192.35M (mesh release) allow both mesh and standard lwapp, but I have doubts and don't find documents about how make this downgrade.
thanks !
Claudio
GregL Mon, 02/16/2009 - 11:15
Claudio were youworking with Cisco TAC for the downgrade. Did they recommend going back to the 4.1.192.35M
In looking at Cisco wireless software download area there looks like there is 5.2.178. You may try looking at the release notes on the 5.2.178 to see if it fixes your problem.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn521780.html
See if this helps.
Greg
rezende.c Mon, 02/16/2009 - 11:27
Greg, Yes, I opened the case on TAC about the bug CSCsv69899 (controller crash and reboot) and they recommend 4.1.192.35M.
I saw the 5.2.178 but I'm worry because this release have a lot of Caveats.
Claudio
GregL Mon, 02/16/2009 - 11:47
I understand your concerns. However alot of the wireless codes have alot of unresolved caveats still. In my opinion to may. I cant believe they dont fix more of the unresolved caveats when they release a new version of code.
You may ask you TAC engineer you were working with about the downgrade error you are getting.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
