Flapping vlan's after guest network setup
Feb 16th, 2009
  • Bronze, 100 points or more
I did quite abit of work on our wireless network last night and I'm seeing alot of these logs on our core switch after the work...
069130: Feb 16 12:36:20 CST: %SW_MATM-4-MACFLAP_NOTIF: Host 0018.de81.37ed in vlan 140 is flapping between port Gi1/0/37 and port Po2
069131: Feb 16 12:37:44 CST: %SW_MATM-4-MACFLAP_NOTIF: Host 0021.5c46.12cd in vlan 140 is flapping between port Po2 and port Gi1/0/37
069132: Feb 16 12:39:10 CST: %SW_MATM-4-MACFLAP_NOTIF: Host 001d.e058.f78b in vlan 140 is flapping between port Gi1/0/37 and port Po1
The network here is in the shape of a "V" using 3750-E stacks with the bottom of the "V" being the core 3750-E stack doing the routing for our vlan's. I have 20Gig channels (LACP) creating the "V" between the stacks...Po1 and Po2. I have about 20 1252's and six 1131's connecting back to a 4404 controller...the controller is connected to port 1/0/37 on the core stack.
My vlan's are..
900 - Management vlan
140 - secure wireless
144 - employee guests
145 - guest
I setup our guest networks and H-REAP local switching last night. All wireless networks seem to work fine including the web authentication page for my guest networks. I configured the controller switch interface as a trunk, native vlan 900, and allowed the four vlan's above on the trunk. I did the same to all my AP's...configured the switch interfaces as trunks, native vlan 900, and allowed the four vlan's above on the trunk.
All the AP's were set to H-REAP local switching, native vlan 900 on the controller H-REAP page and the VLAN ID's are correct on the three SSID's I have.
I initally had LAG configured on the controller (this is the last item I did) when I noticed the logs. I removed the three additional interfaces from LAG on the switch, removed the port-channel etc... but the flapping continues.
Did I do something wrong???
Scott Fella Mon, 02/16/2009 - 19:30
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Post your show run-config and you switch port config.
If you setup all your ap's in h-reap, are they locally switched or still centrally switched? For them to be locally switched, you must configure the local vlan mapping on the ap or else they will all tunnel back to the wlc.
Verify that your port-channels and etherchannel ports are allowing the correct vlans.
When you said you removed the three interfaces from LAG, did you not allow vlan 140 ,144 & 145?
mike-greene Mon, 02/16/2009 - 23:46
Thanks Fella5,
Been on the phone with TAC for 4 hours.
Looks like since I was running H-REAP local switching and the AP interfaces were trunked, the controller interface trunk should not have had the 140,144 and 145 vlans on them.
I now have only the management vlan (900) on the controller trunk and the native vlan is set to 900 as well....do I even need a trunk to the controller??
Anyway, it looks like it's working. I can see clients connected, getting IP addresses, the vlan flapping is gone and I can ping them from around my network.
Thanks for all the posts you and others give on H-REAP, guest networks etc. I did all my configuration from this forum and I really appreciate it.
Scott Fella Tue, 02/17/2009 - 07:02
  • Hall of Fame,
    2017 Wireless
You should keep the trunk port and the native vlan setting. It's best practice and just allow your management vlan.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
