"event id 16640" in event viewer slowing down LMS 3.0
Feb 16th, 2009
HI,
My LMS 3.0 is very slow. Process CPU nearly 100% and error message all the time in event view (see attached file)
I have trie d to resart the server several time, but the message is still there.
Do you know thi pb ?
Rds
Michel.
Joe Clarke Mon, 02/16/2009 - 11:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to upgrade to DFM 3.0.4, and this problem will be fixed. You're seeing CSCsm04957.
mmisonne Mon, 02/16/2009 - 13:01
Hi Jim
Thanks a lot.
That will certainly solve my pb.
Do you know if I can upgrade directly from DFM 3.0.0 to 3.0.4 , because in the release note they say "verify that DFM 3.0.2 or 3.0.3 is installed" but do I need to upgrade first to dfm 3.0.2 and where can I find this release ?
Ragards,
Michel.
