dsp resources
Feb 16th, 2009
Hi there !
I'm having a problem with dspfarm.. the router in using only the PVDM2-64 and PVDM2-32 ... those are onboard pvdm's
How can I start using the PVDM-12 cards that are in NM-HDV?
Router Configurations
! Onboard
voice-card 0
no dspfarm
dsp services dspfarm
! NM-HDV
voice-card 1
no dspfarm
! ERROR when I tryied to configure DSP resource
(config)#voice-card 1
(config-voicecard)#dsp services dspfarm
dspfarm is configured for NM-HDV2 card.
Only one dspfarm type is allowed.
sccp ccm group 988
associate profile 6 register XCODE1234
dspfarm profile 6 transcode
codec g711ulaw
codec g729r8
codec g729br8
codec g711alaw
codec g729abr8
codec g729ar8
maximum sessions 8
associate application SCCP
show inventory
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V03 , SN: FTX1038A5QD
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "Two port E1 voice interface daughtercard"
PID: VWIC-2MFT-E1= , VID: 1.0, SN: 34840061
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32 , VID: V01 , SN: FOC10301UQX
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC1038277V
NAME: "High Density Voice on Slot 1", DESCR: "High Density Voice"
PID: NM-HDV= , VID: 1.1, SN: JAE07361AED
NAME: "E1 (2 Port) Multi-Flex Trunk (Drop&Insert) WAN Daughter Card on Slot 1 SubSlot 0", DESCR: "E1 (2 Port) Multi-Flex Trunk (Drop&Insert) WAN Daughter Card"
PID: VWIC-2MFT-E1-DI= , VID: 1.0, SN: 30888188
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 1", DESCR: "PVDM 3-C549 Simm"
PID: PVDM-12= , VID: 1.1, SN:
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 2", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 3", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 4", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 5", DESCR: "PVDM 3-C549 Simm"
Thanks.
Andrei.
Overall Rating: 5 (1 ratings)
Marwan ALshawi Mon, 02/16/2009 - 17:59
wit hDsp there is tow baisic commands
first you need to enable the dsp on the voice port
with dsp farm command in you case on both voice-card 0 and 1
voice-card 0
voice-card 0
dspfarm
no win your router you have a dsp chip on you r mainboard which is 0 and other one in card 1
u can share the DSP resource from the one on mainboard by issueing the following command
voice-card 0
u need ur voice card look like
voice-card 0
dspfarm
voice-card
dspfarm
use show voice dsp for troubleshooting as well
good luck
hope this helps
Chris Deren Mon, 02/16/2009 - 18:06
Actually, in order to share the PVDMs from different NMs all you need is dspfarm command under the voice-card as I stated earlier, dsp services depfarm allows you to configure the PVDMs for media sharing i.e. conferencing. These 2 get confused by folks all the time, but they have their own specific functions.
Chris
pauleversonCFH Thu, 11/03/2011 - 09:07
I have just stumbled across this post.
Did you ever get this working?
I am struggling to get a HM-HDV with 5 x PVDM-12's to join a dspfarm that currently contains 4 x PVDM2-64's
Should this work?
andrei.goncalves Thu, 11/03/2011 - 10:12
Wow.... that’s a 2003 question.... I don’t remember if I solved that or how… sorry..
Now I have another voice gateway (2911 with lots of PVDM’s…)
Andrei.
De: pauleversonCFH
Enviada em: quinta-feira, 3 de novembro de 2011 14:08
Para: Andrei Goncalves
Assunto: - Re: dsp resources
Home
Re: dsp resources
created by Paul Everson in IP Telephony - View the full discussion
