How to change the interval MARS logs to SDEE client
Feb 16th, 2009
Hi there,
Is there any way to decrease the number of logons from MARS to the router running secure http server and ips with SDEE enabled. I see that it happens every 30 seconds (192.168.14.5 is MARS device)
008489: Feb 16 19:18:42.056: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: Store_Admin999] [Source: 192.168.14.5] [localport: 443] at 11:18:42 PST Mon Feb 16 2009
008490: Feb 16 19:19:12.263: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: Store_Admin999] [Source: 192.168.14.5] [localport: 443] at 11:19:12 PST Mon Feb 16 2009
008491: Feb 16 19:19:42.691: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: Store_Admin999] [Source: 192.168.14.5] [localport: 443] at 11:19:42 PST Mon Feb 16 2009
Overall Rating: 4.3 (3 ratings)
Farrukh Haroon Tue, 02/17/2009 - 00:04
  • Red, 2250 points or more
Hello Zheka
I don't thihk this feature is currently supported on MARS, you can push throught your Cisco Account Team if this feature is required in future releases (for whatever reason).
Farrukh
rajett Tue, 02/17/2009 - 07:01
  • Cisco Employee,
Correct. It's not adjustable.
There's a setting in IOS for the number of connections via SDEE if you are running into troubles of not being able to connect.
