2801 router loses a command line after reboot
Feb 16th, 2009
Have you ever seen where a Cisco router "lose a command line and then will not accept a command line?
First of all, before rebooting a 2801 RTR I wrote the config and then rebooted the router.
After the reboot we started having incoming email issues. I checked the config and somehow it “lost” a line in the config.
So I put the line back in and wrote the config, again. Usually if a RTR doesn't like a command line it'll say something. but the rtr didn't say anything.
I then did a "sh run" and the line was gone!
Thoughts?
garyrivers Mon, 02/16/2009 - 12:39
i tried both ways....
i copied the line from a backup.
and i typed it in manually.
the line i'm trying to get into the RTR is:
ip nat inside source static tcp 10.30.47.5 25 66.140.170.131 25 extendable
Mohamad Qayoom Mon, 02/16/2009 - 12:44
  • Bronze, 100 points or more
Do you see it when you do "sh ip nat translation" ?
garyrivers Mon, 02/16/2009 - 13:02
pages and pages of NAT translations.
which tells me it's working but why can't i see that line in the config?
