Headset Issue on 7960s
Answered Question
Feb 16th, 2009
I'm having a weird issue with a 7960. I'm trying to setup a Plantronics C555 Wireless headset with it. The headset port on the phone doesn't seem to work though. If I connect the headset to the headset port and press the headset button and the call button on the headset, it doesn't work. However, if I connect it to the main phone headset port and take the phoneset offhook, the wireless headset works. Anybody experienced this before?
Correct Answer by Rob Huffman about 8 years 6 days ago
Hi Brett,
On the base of the CS55 have you set the "Compatibility Wheel" to 4. Also check the config for the 7960 in CCM Device>Phone to make sure the Headset port has not been disabled;
Product Specific Configuration
**Disable Speakerphone and Headset
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 02/16/2009 - 15:06
Hi Brett,
Hope this helps!
Rob
