interface ranfe f0/1-24 or interface range fa0/1-24 ?
Feb 16th, 2009
Hi every body!
If i have to select 24 fastethernet ports
I can use:
interface range fastethernet 0/1-24
But i also encountered this:
Can the above command be typed as
" interface range f0/1-24"
thanks a lot!
Roberto Salazar Mon, 02/16/2009 - 18:56
Yes, you can.
switch(config)#int range f?
FastEthernet >> as you can see there is no other option for anything beginning with "f".
switch(config)#int range f ?
<1-6> FastEthernet interface number
switch(config)#int range f 1/24
switch(config)#interf r f1/1-24
goulin Mon, 02/16/2009 - 21:19
The command f0/1 - 24 will work, as will fa0/1 - 24, as will fastEthernet0/1 - 24. The IOS knows that you are abbreviating FastEthernet by using f or fa (or anything that spells the word out) so it will work, since there are no other interface types that start with f (at least on most switches anyway).
danielmassey Mon, 02/16/2009 - 22:44
yes this command will also work fine.
Switch(config)#int range f0/1-24
