Aaron Harrison Tue, 02/17/2009 - 03:36
  • Community Spotlight Award,
    Member's Choice, May 2015
You can use pickup groups with hunt groups, however you have to enable the functionality as it's not there by default.
By default, any call arriving from a hunt group cannot be picked up at all, regardless of which phone it is ringing on.
Go into Enterprise Parameters in CCMAdmin
Scroll down to find Cisco Support Use 1
Enter the following case-sensitive string:
CSCsb42763
Save this.
When you go to the Hunt Pilot, you will see a Call Pickup group option.
Set this and the normal pickup options will all work.
Aaron
Please rate helpful posts...
