Inter-VLAN loop
Feb 16th, 2009
How can I avoid loop between two different VLANs. I have already activated RPVST+ on all the switches.
ccannon88567 Tue, 02/17/2009 - 02:46
What makes you think that you have a L2 loop?
RPVST+ and PVST+ should prevent this? It may be that you have some incorrect additional fine tuning STP statements such as port fast applied incorrectly?
Dorwin Caballero Tue, 02/17/2009 - 05:02
Hi, the problem is like this, one port is switchport access vlan 10 was accidentally connected to a patch panel connected to switchport accesds vlan 20. The network went down and the error loopback was detected. We have around 20 VLANs on our core/L3 switch.
Skjalg Eggen Thu, 11/04/2010 - 03:35
Port security on access ports should do the trick.
The problem still exists, however, if you have trunk ports configured for your IP-Phones and some user decides to plug the PC end of the phone back into the other patch in the wall. This is bad. And I have yet to find a good solution to this problem.
Inter-VLAN loops on trunk ports. Possibly storm-control could be of some help?
