Cann't open/start Device Discovery
Feb 17th, 2009
yesterday I installed CiscoWorks LMS3.1 and everything seemed fine. I started Device Discovery and few times I refreshed it and could see that some devices had been discovered and last time when I had refreshed I got the exception:
The server encountered an internal error () that prevented it from fulfillinf this request.
The full stack trace of the root cause is available in the Apache Tomcat/5.5.17.logs
I thought that next time when I log in and start Device Discovery everything will go fine cause in this exception I get some Read timed out. but, unfortunately I was wrong. This morning I tried to open Device Discovery page and I got the same exception.
Do you have any idea what could happened and what should I do to start device discovery?
Thx,
Jelena
Joe Clarke Tue, 02/17/2009 - 07:46
Run the command:
pdterm CSDiscovery
Then see if you can view Discovery Status.
jardalic1 Tue, 02/17/2009 - 23:29
hi,
just to let you know that this is known bug
- CSCsq63152 HTTP Status 500 error thrown while launching Discovery screen
And it's said that after a while, the screen will be launch able with no issue.
In my case, I tried to refresh page for like 10 to 15 times and it didn't help, but restart of server did :)
Br,
Jelena
Joe Clarke Wed, 02/18/2009 - 09:36
The problem is actually due to a hung CSDiscovery process. When this happens, it no longer services RPC requests. The quick workaround is to shut it down. This will cause the web frontend to look at a static file to get Discovery status.
