6513 Log messages
Hi all,
I am getting some odd messages on the switch logs & log server. Pls see below sample. Does anyone know what they mean?.
TiIsrSpanCo 1
TiIsrPktCon 40
TitanIsrMainHandler C38
TiIsrMETDec 3
TiIsrPktPay 1
TiIsrSpanCo 1
TiIsrPktCon 40
TiIsrMETDec 3
TiIsrPktPay 1
TiIsrSpanCo 1
TiIsrPktCon 40
TiIsrMETDec 3
TiIsrPktPay 1
TiIsrSpanCo 1
TiIsrPktCon 40
TiIsrMETDec 3
TiIsrPktPay 1
TiIsrSpanCo 1
TiIsrPktCon 40
TiIsrMETDec 3
Rgds.
Harry
Giuseppe Larosa Tue, 02/17/2009 - 02:40
  • Hall of Fame,
    Founding Member
Hello Harry,
these messages are likely coming from some ASIC named Titan
I had a similar issue some times ago and we solved opening a case: with an IOS upgrade the problem was solved.
Open a Service Request you can have a faulty hardware or the current IOS doesn't support correctly some linecards
do you see all modules ok in sh module ?
Hope to help
Giuseppe
Roberto Salazar Tue, 02/17/2009 - 10:10
  • Gold, 750 points or more
One of them either has debug on or "service internal" is enabled. It looks like the messages are internal messages. Check you're config on the switch logging the message and look for "service internal", if you see it remove it with "no service internal", if the message is continuous you should be able to verify if removing it made an immediate impact. try it and let us know.
mcdvikram Fri, 01/16/2015 - 21:18
i have same issue
TitanIsrMainHandler 38
TiIsrSpanCo 51
TiIsrPktCon 40
TiIsrSpanCo 51
TiIsrPktCon 40
TiIsrSpanCo 51
TiIsrPktCon 40
TiIsrSpanCo 51
TiIsrPktCon 40
TiIsrSpanCo 41
TiIsrPktCon 40
TiIsrSpanCo 51
TiIsrPktCon 40
do any  one found any solution of this ?.
