02-17-2009 02:35 AM - edited 03-18-2019 10:30 PM
implemented ssl on unity, how do we change tray icon to be https - must be a reg setting or advanced setting tool entry...cheers, jag
Solved! Go to Solution.
02-17-2009 03:53 AM
Enter Regedit
Expand the key
HKEY_LOCAL_MACHINE\SOFTWARE\Active Voice\SystemParameters\1.0.
In the left pane, right-click 1.0, and click New > DWORD Value.
Name the value EnforceSSL.
In the right pane, double-click EnforceSSL.
Change Value Data to 1.
Click OK to save the change.
Aaron
Please rate helpful posts...
02-17-2009 03:53 AM
Enter Regedit
Expand the key
Aaron
02-17-2009 06:02 AM
Hi Aaron,
thanks for your help, any further steps required? that did not work unfortunetly?
02-17-2009 06:52 AM
Would help if I could spell EnforceSSL - that worked a treat, thanks..Jag
