Chris Deren Tue, 02/17/2009 - 06:14
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You can simply see where their mailbox is, if it's the same as their email then they are using it as UM, if the mailbox is something other than the email mailbox than it' VMO.
Chris
Michael Mistretta Tue, 02/17/2009 - 07:52
Another way to check is to look at the licensing in unity admin. It will tell you license available and use
Chris Deren Tue, 02/17/2009 - 07:54
  • Hall of Fame,
Looking at licensing will only tell you how the user was configured, does not mean that the user is actually used as UM or VMO, it's just a setting in COS. Also, Unity 4.2 and below did not have separation for UM and VMO.
HTH,
Chris
Michael Mistretta Tue, 02/17/2009 - 07:57
Thanks Chris. Its been quite some time since I have dealt with 4.2. I did not realize that it didn't specify.
Chris Deren Tue, 02/17/2009 - 07:59
  • Hall of Fame,
Michael,
You work for Meridian IT in Deerfiled?
Say hello to Christian, Craig, and Todd from me :-)
Chris
