cannot login ciscopca
Feb 17th, 2009
When I try to connect to ciscopca I get the following error:
Unable to contact server. Try logging on again in a few minutes. If the problem persists, contact your Cisco Unity administrator.
I have done some reading I checked the TCP ports with tcpvcon.exe but I can not find anything. I resolve it with a reboot of unity server.
Normally the next day this error reoccurs.
Any thoughts?
This is a demo environment in our lab, but I can hardly propose this or show this to potential customers or the sales depth, nor do I want to unless I find out why I have this error.
j.huizinga Thu, 02/19/2009 - 00:49
Hello Brad,
Yes you are right I have an security error:
2009-02-19 10:37:08.994 [Thread-9] ERROR - AvxmlConnector.generateResponse() IOException Server returned HTTP response code: 401 for URL: http://UNITY/Avxml/AvxmlSvr.dll
2009-02-19 10:37:08.994 [Thread-9] WARN - sendEnvelope: no response generated
2009-02-19 10:37:09.291 [Thread-9] ERROR - sendEnvelope() - send failed returning fault
2009-02-19 10:37:09.291 [Thread-9] ERROR - populateLogonModel - error retrieving logon information - fault - server must be down
<?xml version="1.0" encoding="UTF-16"?>">
Connection to the unity server(s) has failed
2009-02-19 10:37:09.291 [Thread-9] ERROR - perform - Attribute "PROVIDER" unknown/unset value: null
2009-02-19 10:37:09.291 [Thread-9] WARN - perform - Attribute "PROVIDER" will be defaulted to: Windows
But the AvXml directory in IIS allows anonymous access.
After a reboot of the unity server I have access for some time.
Is there some more security parameters to look at?
Christopher McAlpin Thu, 02/19/2009 - 19:21
What version of Unity, do you have any Engineering Specials installed?
There have been a few CPCA issues resolved in Engineering Specials. Some require installing an ES and a few post installation requirements.
j.huizinga Fri, 02/20/2009 - 03:33
Brad and Christopher,
Thanks for your replies.
At this moment I am not in the office, so I can not try it.
On Monday I shall do some checking,
j.huizinga Wed, 03/04/2009 - 00:31
I checked all the things that are mentioned in the links and all is OK.
Problem is: It works, the next day it doesn't. After a reboot it works fine for another day.
I am, using Unity 5.0(1)
Maybe I should try some upgrade's?
j.huizinga Mon, 03/09/2009 - 04:43
I am running win2K so I have IIS 5.0 and I don't think Application pools are supported on IIS 5.0
I can run Unity 5 on Win2K? I installed it without problems and I the installation manual says it supports 2K and 2003
