Notification sent, invalid or corrupt AS path
Feb 17th, 2009
We had a problem yesterday where our BGP session kept on resetting because of the following error.
Would anyone know if the latest version of cisco IOS fixes this ?
Connections established 10; dropped 10
Last reset 00:00:02, due to BGP
Message received that caused BGP to send a Notification:
FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
02310200 00021640 01010050 02020002
FF04F905 1371B9BA FCBAFCBA FCBAFCBA
FCBAFCBA FCBAFCBA FCBAFCBA FCBAFCBA
FCBAFCBA FCBAFCBA FCBAFCBA FCBAFC40
0304D0AF F765C008 0404F955 F0155E7D
D8
No active TCP connection
Thanks in advance for any help.
Dave
webhostireland Tue, 02/17/2009 - 08:17
Andrew,
I dont know if it is a bug or by design.
Maybe the latest version of Cisco ios will handle the invalid AS path differently ?
I dont know why the router doesnt disregard the prefix with bad AS path and keep the BGP session alive.
Dave
Dave,
I understand where you are coming from, but upgrading is not a fix all solution.
A reboot fixes all right?!
What I am trying to say - is without definitive information that says this is a bug or by design - to upgrade may make things worse. I personally would be searching the bug track to see if this is an actual issue - or just a one off, where a device reboot would actually work.
Let me ask you - how long as the router be running/routing BGP before this hicup? Have you had any other issues with this device in the past? have you been running the version of IOS since you took the router out the box?
webhostireland Tue, 02/17/2009 - 08:51
Andrew,
We actually had 2 seperate routers that reset their BGP sessions after the invalid AS paths yesterday.
No other problems with either routers. Same IOS on both routers for years.
They would be up for around 6 months or so.
I know that other ISP's had a similar problem also between 4:40pm - 5:30pm GMT yesterday.
Dave
