VPN Failover with backup ISP -- ASA 55xx
Feb 17th, 2009
I have to implement a failover VPN via a second ISP.
ASA is set up with
int outside1 default route tracked and static IP.
int outside2 default route not tracked metric 2 and dynamic IP :-(
There is a site-2-site IPSEC VPN to a data center..
Now, the customer want to have the VPN up in failover case, too.
I can think of:
1. dyn DNS :-(
2. Easy VPN with network extension
does anybody has any expieriences either way? or other suggestions??
husycisco Tue, 02/17/2009 - 05:44
Hello Ralf,
As far as I know, ASA does not support DDNS the way you propose. EasyVPN looks like the only option. Your client should be configured as the EzVPN server btw.
vitesse-it Tue, 02/17/2009 - 06:32
I did tinker a solution w/ dyndns once, don't like it, tho.
I am not happy w/ ezVPN either. It makes me so unflexible for further VPN's
Just wondering if s.b. has better ideas :-)
