Aironet 1310 - not able to establish UDP vpn
Feb 17th, 2009
We hv installed aironet 1310 in AP as well as root and non root bridge combination with IOS 12.4(3g)JA1.
config works fine for the normal operation like getting client connected to ap, getting IP from DHCP server on the network. The problem is with the UDP vpn. We hv an application which after getting DHCP ip establish the UDP vpn connection which always fails. Aironet 1310 is connected cisco switches.
At some of the AP/bridge playing with the cisco switch setting (speed and duplex) it do work. But that is only a try and error method. But with few other root bridge even trying the same combination doens't work.
Has anyone experience such issue ? Is there any config changes to be made for such UDP vpn ?
Early help would be appreciated.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
