CM 4.2 Design question
Feb 17th, 2009
Hi there,
I have the CM4.2 in cluster in the main office...
Now I have a remote site with 3825 connected to a Avaya PBX through an E1
Now I'm in doubt:
- I created a H323 gateway with the 3825 IP address
- I created a MGCP for registering it's E1 interface in the CM4.2, so I can create the route patterns, for local phones..
- I configured the SRST reference for it's IP
Is this right ? Should I configure anything else to integrate the remote 3825 to CM ?
Thanks.
Andrei.
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 02/17/2009 - 06:20
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do you have Cisco IP phones at this remote site?
Any other circuits besides the E1 to Avaya?
If there are no phones, there is no need for SRST, also is there a specific reason you need to run both MGCP and H323?
Besides configuring route patterns and GWs, there is plenty of other things you would want, such as paritions, calling search spaces, media resources, etc.
HTH,
Chris
andrei.goncalves Tue, 02/17/2009 - 06:27
yes, I have ip phones there
There is no other circuit, only one E1 to Avaya.. the Avaya is connected to PSTN.. so I'll need to route the calls to it.
I already have a DevicePoll, Partitions and CSS.. and other configs to remote phones...
So, can I remove h323 ?
I'm trying to route calls to Avaya, but I had no success.. I configured an ip phone here at main office with the configurations of an ip phone of remote site.. my ip phone's CSS have a route to avaya interface (already registered via MGCP)
But I only receive a fast busy tone...
Feb 17 14:17:38.010: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0008
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '7713'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '4236'
Feb 17 14:17:38.034: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8008
Cause i = 0x81D2 - Identified channel does not exist
Thanks.
Andrei.
Chris Deren Tue, 02/17/2009 - 06:34
  • Hall of Fame,
Please post your entire config, is the PRI connecting to Avaya MGCP or H323 controlled?
Notice "Cause i = 0x81D2 - Identified channel does not exist " error.
What does "sh isdn status" show?
How is your clocking configured, who is the master and who is the slave? We can tell this from the full config.
Chris
andrei.goncalves Tue, 02/17/2009 - 06:47
Sorry not to post all config.. I hope you have in this config all information you need.. If you need more, let me know.
thanks.
Andrei.
show isdn status
#show isdn status
Global ISDN Switchtype = primary-qsig
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial1/0:15 interface
dsl 0, interface ISDN Switchtype = primary-qsig
**** Slave side configuration ****
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 3
Total Allocated ISDN CCBs = 0
running config
card type e1 1 1
network-clock-participate slot 1
isdn switch-type primary-qsig
voice-card 0
voice-card 1
controller E1 1/0
pri-group timeslots 1-31 service mgcp
description
controller E1 1/1
description
interface Loopback10
interface Loopback30
interface Loopback34
interface Loopback90
interface Loopback101
interface Loopback102
interface Loopback103
interface Loopback104
interface Loopback105
interface Tunnel9100210
interface Tunnel9100230
interface Tunnel9100234
interface Tunnel9200290
interface GigabitEthernet0/0
ip address 10.91.1.22 255.255.255.0
ip access-group ACL_ENTRADA_LAN in
no ip redirects
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
ip tcp adjust-mss 1300
ip policy route-map ROTA
no ip mroute-cache
duplex full
speed 100
media-type rj45
service-policy input MARCA_PACOTE
interface GigabitEthernet0/1
interface Serial0/0/0
interface Serial0/0/1
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 6000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
voice-port 1/0:15
output attenuation -6
echo-cancel coverage 32
timeouts initial 20
timeouts interdigit 15
description -- ccs/Q.sig
ccm-manager redundant-host 10.1.9.36
ccm-manager mgcp
ccm-manager fax protocol cisco
ccm-manager config server 10.1.9.35
mgcp
mgcp call-agent 10.1.9.35 2427 service-type mgcp version 0.1
mgcp fax t38 ecm
mgcp profile default
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.91.1.22 port 2000
max-ephones 25
max-dn 25 dual-line
system message primary En modo local
time-format 24
date-format dd-mm-yy
Chris Deren Tue, 02/17/2009 - 06:53
  • Hall of Fame,
I see that you are using QSIG, is QSIG supported and configured on your Avaya? Typically it requires additional license and configuration on TDM PBXes.
Add the following commands:
mgcp bind media source-interface GigabitEthernet0/0
mgcp bind control source-interface GigabitEthernet0/0
Also, ensure things are properly configured on Avaya side.
Chris
andrei.goncalves Tue, 02/17/2009 - 07:58
Ok, I applyied those commands. Thanks.
About Qsig configuration, I think it's fine ... well, the Avaya extension is able to call me. But I agree with you, I'll try to make sure about Avaya config.
Avaya has a route 831XXXX that goes to E1 (cisco) and translate to XXXX
And I keep receiving a fast busy...
this is an debug from Avaya extension calling cisco extension
debug isdn q931
Feb 17 14:55:06.474: ISDN Se1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00CC
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0xA1838F
Preferred, Channel 15
Progress Ind i = 0x8183 - Origination address is non-ISDN
Locking Shift to Codeset 6
Codeset 6 IE 0x28 i = 'BENITO OLVERA'
Feb 17 14:55:06.754: ISDN Se1/0:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x80CC
Channel ID i = 0xA9838F
Exclusive, Channel 15
Feb 17 14:55:07.710: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00CC
Called Party Number i = 0x81, '4'
Plan:ISDN, Type:Unknown
Feb 17 14:55:08.406: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00CC
Called Party Number i = 0x81, '2'
Feb 17 14:55:08.658: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00CC
Called Party Number i = 0x81, '7'
Feb 17 14:55:08.906: ISDN Se1/0:15 Q931: RX <- INFORMATION pd = 8 callref = 0x00CC
Called Party Number i = 0x81, '8'
Feb 17 14:55:09.490: ISDN Se1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80CC
Feb 17 14:55:09.490: ISDN Se1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x80CC
Progress Ind i = 0x8088 - In-band info or appropriate now available
Feb 17 14:55:13.154: ISDN Se1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80CC
Feb 17 14:55:13.190: ISDN Se1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00CC
Feb 17 14:56:55.764: ISDN Se1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x00CC
Cause i = 0x8190 - Normal call clearing
Feb 17 14:56:56.588: ISDN Se1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x80CC
Feb 17 14:56:56.612: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x00CC
Anything else that I could check ?
Thanks.
Andrei.
Chris Deren Tue, 02/17/2009 - 08:04
  • Hall of Fame,
Also, make sure this is not configured as partial PRI on Avaya side, you can easily check this by changing the order on Cisco side, change:
to
isdn bchan-number-order descending
HTH,
Chris
andrei.goncalves Tue, 02/17/2009 - 08:18
Done.. what I think is strange is that is only one port becomes "up" for a second...
using ascending ou descending, the same por becomes up for a sec...
1/0:15 > 31
#sh voice port summary | include xcc
1/0:15 01 xcc-voice up none none none y
1/0:15 02 xcc-voice up none none none y
1/0:15 03 xcc-voice up none none none y
1/0:15 04 xcc-voice up none none none y
1/0:15 05 xcc-voice up none none none y
1/0:15 06 xcc-voice up none none none y
1/0:15 07 xcc-voice up none none none y
1/0:15 08 xcc-voice up none none none y
1/0:15 09 xcc-voice up none none none y
1/0:15 10 xcc-voice up none none none y
1/0:15 11 xcc-voice up none none none y
1/0:15 12 xcc-voice up none none none y
1/0:15 13 xcc-voice up none none none y
1/0:15 14 xcc-voice up none none none y
1/0:15 15 xcc-voice up dorm none none y
1/0:15 17 xcc-voice up none none none y
1/0:15 18 xcc-voice up none none none y
1/0:15 19 xcc-voice up none none none y
1/0:15 20 xcc-voice up none none none y
1/0:15 21 xcc-voice up none none none y
1/0:15 22 xcc-voice up none none none y
1/0:15 23 xcc-voice up none none none y
1/0:15 24 xcc-voice up none none none y
1/0:15 25 xcc-voice up none none none y
1/0:15 26 xcc-voice up none none none y
1/0:15 27 xcc-voice up none none none y
1/0:15 28 xcc-voice up none none none y
1/0:15 29 xcc-voice up none none none y
1/0:15 30 xcc-voice up none none none y
1/0:15 31 xcc-voice up up none none y
andrei.goncalves Thu, 02/19/2009 - 03:41
Hi there !
I'd like to say thanks for your help.
I left only the MGCP config... the problem was the network side.. I changed that in CM4.2 and works.
One thing .. I had to access the router to restart the controller because reseting using CM was not working...
Thanks.
Andrei.
mightyking Tue, 02/17/2009 - 06:49
Andrei,
If the Avaya PBX and Cisco CCM are networked, the easest way is to use an H.323 trunk directly from Avaya PBX to Cisco CallManager and a H.323 Gateway from Cisco CCM to Avaya PBX. All you need is to creat location/region and the codec (G.729)and map the desired digits into a route pattern in both ends. I have just finished one with H.323 Trunk/GW and so far is working fine.
MK
andrei.goncalves Thu, 02/19/2009 - 06:56
Hi about having MGCP and H323 configured...
I have 1 E1 with PBX (QSIG) and 1 E1 with R2 (non qsiq) with pstn...
That is the reason for both protocols.
Thanks.
Andrei.
