LMS 3.1 common services 3.2
Feb 17th, 2009
I was unable to move the syslog backup driectory via the gui. I ran the syslogConf.pl script to change the directory. The log file increments but I am now unable to start the daemon service. I get the message the service has started, the service has stopped, no errors reported
Joe Clarke Tue, 02/17/2009 - 08:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I assume you mean you relocated the syslog log file. If so, what is the path to the new location? Please post the NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties file.
damoroney Wed, 02/18/2009 - 01:39
yes i ran syslogConf.pl to relocate the syslog to d:/syslog-backup directory and now I am unable to start crmdmgtd. the service starts then stops immediately, with run net start crmdmgtd or starting the service in admin tools.
file as requested
# Timezone related properties
TIMEZONE=PST
COUNTRY_CODE=USA
TIMEZONE_FILE=$NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/fcss/data/TimeZone.lst
# General properties
SYSLOG_FILES=d:/syslog-backup/syslog.log
DEBUG_CATEGORY_NAME=SyslogCollector
DEBUG_FILE=$NMSROOT/log/SyslogCollector.log
DEBUG_LEVEL=INFO
DEBUG_MAX_FILE_SIZE=5MB
DEBUG_MAX_BACKUPS=3
DOWNTIME_DIR=$NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data
FILTER_DUMP_FILE=$NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/filters.dat
# Miscellaneous properties. These are not important to users.
READ_INTERVAL_IN_SECS=1
QUEUE_CAPACITY=100000
PARSER_FILE=$NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/fcss/data/FormatParsers.lst
SUBSCRIPTION_DATA_FILE=$NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Subscribers.dat
FILTER_THREADS=1
COLLECTOR_PORT=4444
damoroney Wed, 02/18/2009 - 01:53
now resolved the issue by running resetCasusuer.exe.
miheg Wed, 02/18/2009 - 05:35
  • Gold, 750 points or more
Ah a permissions problem then....
But resetCasusuer.exe only resets the casuser password. Or does it actually do more?
Cheers,
Michel
damoroney Wed, 02/18/2009 - 05:53
yeas i think a permission problem is at the base of this. I now cannot schdule a backup or change the syslog directory?. Any ideas, the NMSROOT is not program files/CSCOpx but d:/LMS
miheg Wed, 02/18/2009 - 05:55
Not too much ideas...yeah, all files and directories need to be writable for casusers, but beyond that .... not sure
Cheers,
Michel
Joe Clarke Wed, 02/18/2009 - 10:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, it only resets casuser's password, and adjusts the local security policies. However, it does require dmgtd to be restarted, which most likely was the real fix for this problem.
