E1 extension number
Feb 17th, 2009
I have an AS5300 with 8 E1's and r2-digital. I use it to dial-out with telnet. But all calls always apper to come from the caller-id t, one of the main 8 trunk numbers of the E1's. There is a way to set the extension number for each modem for example?
The E1 configuration are:
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country brazil
category 2
answer-signal group-b 1
Paolo Bevilacqua Tue, 02/17/2009 - 09:25
Ola', good question.
I've searched and cannot find a way todo this. Suggest you configure modem-pool and check if any command let you set calling number (ANI)
guilherme.bedin Tue, 02/17/2009 - 10:18
Good suggestion, bellow the modem-pool options:
Modem pool configuration commands:
called-number Map a called number to modem pool
default Set a command to its defaults
exit Exit from modem-pool configuration mode
help Description of the interactive help system
no Negate a command or set its defaults
pool-range Configure a group range for the modem pool
Did you think that called-number will do the trick?
I also found the link bellow, I will read and try latter.
Paolo Bevilacqua Tue, 02/17/2009 - 12:57
No, called-number is to tie a pool to a DNIS. I'm afraid, what you want cannot be done.
