UCCX 7.01 moh
Feb 17th, 2009
Need help in troubleshooting moh in UCCx. Ihave hold/unhold steps in the script but when no agent is loggid in no MOH is heard, just 3 beeps. Using UCM 6.1.2 with a "SampleAudioSource"
Have configured Network Hold MOH in the CTI ports.
Chris Deren Tue, 02/17/2009 - 07:41
What is the logic when there are no agents logged in? The MOH you hear is when call is in queue, and that is when you use the hold/unhold steps, if there are no agents logged in I would imagine you are not sending the call into queue, thus you are not doing hold/unhold steps. Let us know what the logic is and we can assist.
3 beeps indicate MOH configuration issues, where the actual file can not be played, typically due to wrong MRGL being used.
soilemezis Tue, 02/17/2009 - 07:50
Thanks, Chris.
OK my understanding was that calls go into the queue even if no agent is logged in. I can hear the prompt.
The script I am using is uploaded.
