After upgrade to RME 4.0.4 no config-files in shadow directory
Feb 17th, 2009
After upgrade from RME 4.0.3 to 4.0.4 the config-files are not synched in the shadow directory. We still have the old files in it. The path is still /var/adm/CSCOpx/files/rme/dcma/shadow/Switches_and_Hubs/PRIMARY.
The shadow directory is "enabled". The synch to the database is ok.
Joe Clarke Tue, 02/17/2009 - 08:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The configs are old how? Are the timestamps old, or do the configs actually lack changes present on the device?
hsprenger Tue, 02/17/2009 - 08:14
The timestamps are old. We daily synch the switches. We upgrade RME on 22.12.
And now all files remain to that date.
Joe Clarke Tue, 02/17/2009 - 08:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is expected. RME will not update its archive unless it finds an interesting change on the device. An interesting change is one not listed in RME > Admin > Config Mgmt > Exclude Commands. While the dates on the shadow configs may be old, they should point to the latest configuration on the device. If you make a change to a device's config, then sync the archive, the shadow config should also change.
hsprenger Tue, 02/17/2009 - 08:19
Thats what i tried then. I changed something în the config, but no new file exists on the next day.
Joe Clarke Tue, 02/17/2009 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Enable ArchiveMgmt Service debugging under RME > Admin > System Preferences > Loglevel Settings. Change something else on one device's config. Perform a Sync Archive of that device. Post the dcmaservice.log along with the config before and after.
Joe Clarke Tue, 02/17/2009 - 08:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It appears you didn't wait long enough. The actual archive operation is not included. Additionally, I need to see the before and after configurations from the device in question.
Joe Clarke Tue, 02/17/2009 - 10:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There appears to be a permissions issue on /var/adm/CSCOpx/files/rme/dcma/shadow/Switches_and_Hubs/PRIMARY on one of the parent directories. Make sure the perms are:
0660 casuser:casusers
hsprenger Tue, 02/17/2009 - 11:42
That helps. Thank you very much. Great support.
