SPA8000: attended transfer with FLASH does not work
Feb 17th, 2009
I'm having trouble with attended transfers on phones connected to an SPA8000.
If an SPA phone A calls another SPA phone B which in turn, picks the call up and subsequently presses the R key (Flash) and dials another SPA extension C until C picks the phone up and B hangs up, then caller A can talk to caller C (attended transfer is OK).
However, if C is any other type of extension (SIP softphone, ZAP extension ¡, etc) then when B hangs up, the call to C drops and B "rings back" with caller A.
The only way I found to a successful attended transfer if C is not an SPA8000 extension is for B to dial *2 (Asterisk's built-in attended transfer feature).
If I compare the SPA8000 to Grandstream's GXW4008, with the latter, attended transfers with Flash work fine as described above. I would like to have the same behavior on the Linksys SPA8000. Is it possible?
paolo bevilacqua Tue, 02/17/2009 - 12:43
  • Hall of Fame,
    Founding Member
I'm afraid you won't get an answer here.
The linksys voice system is virtually unknown to this forum community. I personally have setup one for a try once, but did not test much on it.
vieri.dipaola Wed, 02/18/2009 - 00:23
Wow, I thought I was going to get "better support" out of Linksys/Cisco.
That's definitely a cold shower.
Thanks for suggesting voxilla. Will try over there.
