ASA Crypto Map Question
Feb 17th, 2009
  • Bronze, 100 points or more
I have roughly 80 sites I need to configure for VPN. Do I have to specify a separate tunnel-group and crypto map sequence number for each? i.e.
site A:
crypto map CisoMap 111 match address 55
crypto map CisoMap 111 set peer 1.1.1.1
crypto map CisoMap 111 set transform-set CiscoXform
tunnel-group 1.1.1.1 type ipsed-l2l
tunnel-group 1.1.1.1 ipsec-attributes
pre-shared-key *
site B:
crypto map CisoMap 222 match address 55
crypto map CisoMap 222 set peer 2.2.2.2
crypto map CisoMap 222 set transform-set CiscoXform
tunnel-group 2.2.2.2 type ipsed-l2l
tunnel-group 2.2.2.2 ipsec-attributes
pre-shared-key *
Overall Rating: 5 (1 ratings)
Ivan Martinon Tue, 02/17/2009 - 10:07
  • Cisco Employee,
Your statement is correct, you need to define a separate crypto map (diff seq no and same name) for each vpn and a separate tunnel-group for each
DialerString_2 Tue, 02/17/2009 - 10:08
Imartino,
Hey thanks for the quick reply!!!!! I was editing my post when you responded.
Thanks again, Imartino.
