Music in call manager
Feb 17th, 2009
how i can change the music in call manager 4.1, that i listen when i put in hope to any person.
How much is the time maximum that can have the song?.
Which is the file format of the song?
Overall Rating: 5 (2 ratings)
Jaime Valencia Tue, 02/17/2009 - 10:51
  • Cisco Employee,
  • Hall of Fame,
    2011
you change it on the line, device, device pool or enterprise parameters. that order in preference.
if you're adding a new MOH then thru the MOH options add a new source
it can be an MP3 or WAV, it'll be translated to the right format for CCM
java
if this helps, please rate
pesanchez2002 Tue, 02/17/2009 - 12:53
When i select:
Service > media resource > music on hold audio source and i select the actual file music, i can see the following information:
imput file name:
filemusic.ulaw.wav
ouput file list:
filemusic.ulaw.wav
filemusic.alaw.wav
filemusic.g729.wav
filemusic.wb.wav
i need to replace filemusic.wav and to maintain the same name "filemusic.wav"
I can copy the filemusic.wav and replace, but how i can replace the 4 output file.
How big may be the file "filemusic.wav"?
Jaime Valencia Tue, 02/17/2009 - 14:20
  • Cisco Employee,
  • Hall of Fame,
    2011
those files are created by the MOH translator, you do not provide those. only the original input file
java
pesanchez2002 Wed, 02/18/2009 - 08:06
I read this:
"If the audio translator translates audio source files on the same server as the
Cisco CallManager, serious problems may occur. The audio translator tries to use
all available CPU time, and Cisco CallManager may experience errors or
slowdowns. Make sure that audio translation never takes place on an active
Cisco CallManager."
How i can do the translation without have problem of services?
Jaime Valencia Wed, 02/18/2009 - 08:06
  • Cisco Employee,
  • Hall of Fame,
    2011
simple, do it afterhours
java
