Debug reset
Feb 17th, 2009
We are using Enable Debug to start debugging on Common Services
Components and according to the User Guide for 3.2 Reset All should Disable All Debugging!
This is not working.
Any sugestions.
Joe Clarke Tue, 02/17/2009 - 10:53
This is working for me. Exactly what debug did you enable? What message do you get when clicking "Reset All"?
aryanadonis Tue, 02/17/2009 - 11:20
There is no error message but the option does not work.
It is LMS 3.1. I can disable the debug manually.
Joe Clarke Tue, 02/17/2009 - 11:25
You should get a pop-up saying that debugging was disabled. Exactly which debugging did you turn on, though? I want to see if I can reproduce doing the exact steps you did.
