Design Network config
Feb 17th, 2009
We have starting a new network setup for our site can any one suggest me how i can deploy the following points on my network
1. I am planning to deploy the STP between access and distribution
2. Running HSRP between two 6500 switch like for some VLAN Switch A will be the primary and other VLAN switch B will be primary
3. In the core connecting to our two site has the two redunant fibre
can any one help me in example config for the attached network diagram
vinoth.kumar Tue, 02/17/2009 - 11:05
Tshi M Tue, 02/17/2009 - 11:48
  • Silver, 250 points or more
I would use L3 between the core switches and the WAN switches and use a routing protocol.
In regards to core to access-layer, i might do what is attached.
rgds,
Mohamed Sobair Tue, 02/17/2009 - 11:40
  • Gold, 750 points or more
Cisco recommends a complete layer-3 Network design between CORE and Distribution including the access layer.
The Complete Layer-3 design has the benifit of the following:
1- Rapid link failure detection.
2- Rapid route Convergence.
You can even implement (BFD) Bidirectional forwarding detection with OSPF or EIGRP.
Pls have a look at the attached documents:
Mohamed
