VPN to ASA with a Private IP
Feb 17th, 2009
Hello All,
I have an ISP that has given me a bunch of public IP's but my gateway is a private address.(point to point to the ISP Router).
I have attached this line to an ASA 5510.
What I want to do is
1) have the ASA with a Private IP on the Outside interface Using 1 Public IP as a VPN Server.
2) 1 Public IP as a Web Server and
3) the 3rd Public IP for surfing from the Inside Interface.
I have tried so far to get my first aim to work without success. I can't even get the ASA 5510 to reply to pings to any of the Public IP Addresses from the Outside that I have configured.
Is this at all possible ?
I have already configured something similar with a ASA 5510 that has a Public IP on the Outside interface - this made the job easy.
Please help.
Overall Rating: 4 (1 ratings)
Fraser Reid Tue, 02/17/2009 - 12:16
This helps loads with the Ping but - can you also help with the Public - Private IP VPN bit too ?
eddie.mitchell@... Tue, 02/17/2009 - 12:21
  • Silver, 250 points or more
Once you've got the public IP assigned to the outside interface. Setting up the additional access should be pretty easy. All you need is a static statement and an ACL for inbound access to your webserver and you can use the outside interface of the firewall for outbound PAT.
This document should help:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008046f31a.shtml
Fraser Reid Tue, 02/17/2009 - 12:27
Thanks Eddie - I will try this and let you know again in the morning - I am working in Germany . getting late here :-)
Fraser Reid Wed, 02/18/2009 - 01:55
Sorry eddie - this didn't solve my main problem - everything else is gone now though.....here a little drawing with a few exaple IP's in it - maybe this makes more sense of what I am trying to do
eddie.mitchell@... Wed, 02/18/2009 - 05:05
So, you've got 12.12.12.1 assigned to the outside interface of your ASA?
Now all you need to do is configure a static and ACL to permit inbound access to your webserver:
static(inside,outside) 12.12.12.2 192.168.1.x netmask 255.255.255.255
access-list outside_in permit tcp any host 12.12.12.2 eq 80
access-group in interface outside
To allow outbound access from your internal clients (will use the outside IP address of the ASA for PAT) you need the following:
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
I won't go into configuring a remote access VPN here, but this document should guide you:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml#cli
Fraser Reid Wed, 02/18/2009 - 08:12
Eddie,
Configured on the outside interface I have 10.250.250.5
So how do I assign the 12.12.12.1 to the same interface so that I can have the ASA accept IPSec connections to this IP ?
This is what I do not understand.
eddie.mitchell@... Wed, 02/18/2009 - 08:42
I think you're only options here would be to set up a static NAT translation on your ISP router (12.12.12.1 -> 10.250.250.5)
(Not sure if this will work with VPN's though)
OR
Reconfigure the ASA to have 12.12.12.1 assigned to the outside interface.
