02-17-2009 12:42 PM - edited 03-15-2019 04:17 PM
We are going to be upgrading our CUCM to version 7.x at some point in the very near future. I read that we have to be running 8.4.x firmware on the phones. I have downloaded 8.4.3 and I want to test it on a couple of phones before pushing it out to all of them. Can this be done?
Thanks, Troy
02-17-2009 01:45 PM
Sure it can, download the service pack containing firmware file you are planning on using after the upgrade, install the service pack and it will change the device defaults to the firmware file included in it, then restart tftp server and all phones should download and install the firmware.
HTH,
Chris
02-17-2009 02:17 PM
if the load has already been uploaded change the load info on the device config page of the phones you want yo try
java
if this helps, please rate
