02-17-2009 01:30 PM - edited 02-21-2020 04:09 PM
HI,
I have an IPSec tunnel from my Cisco 3845 router to a remote vendor Cisco Concentrator.
I have two data streams from 2 hosts on my side that should go through this tunnel.
Both data streams work, however, once the first data stream brings up the tunnel, and the second data stream starts, it looks like it's trying to initiate a new IKE session to the remote peer instead of using the existing tunnel. A show crypto isa sa reveals multiple MM_Init sessions. This of course fails. And it doesn't matter which data stream starts first.
I have other IPSec tunnels on my router, with multiple data streams, and have no issues with them.
Could this be something to do with the concenterator?
We've confirmed ACLs and ISA/IPSec parameters on both ends match.
Any insite is greatly appreciated!
Ray
02-18-2009 01:48 AM
If you type "sh crypto ipsec sa" and look at the local/remote ident values are they using /32 subnet masks?
It may be that you are trying to negotiate new keys per host pair instead of per network subnet.
02-18-2009 07:23 AM
Yes, they have /32 masks on my end and on the remote end.
interface: GigabitEthernet0/0.925
Crypto map tag: B2B_VPN, local addr 207.131.207.136
protected vrf: (none)
local ident (addr/mask/prot/port): (207.130.16.36/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (63.111.231.25/255.255.255.255/0/0)
current_peer 65.201.27.46 port 4500
PERMIT, flags={origin_is_acl,}
local ident (addr/mask/prot/port): (170.108.4.1/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (63.111.231.35/255.255.255.255/0/0)
current_peer 65.201.27.46 port 500
