Warning message
Router 2600 CPU Usage 100%
Answered Question
Feb 17th, 2009
I have the below router in production which is showing CPU usage 100% during some file transfer between the segments.
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(19), RELEASE SOFTWARE (fc2)
I am using only two fast ethernet interfaces on this router which are connected to a cisco switch and are autonegotiated to 100MBPS. IP CEF is also set on the router.
Is it natural for the router to show CPU usage 100% during big file transfer? Is there any work around?
Correct Answer by Leo Laohoo about 8 years 6 months ago
The 3560 is a multi-layer (L2/L3). You can do OSPF if you have the Enhanced license installed.
Overall Rating: 4 (2 ratings)
paolo bevilacqua Tue, 02/17/2009 - 17:59
  • Hall of Fame,
    Founding Member
There is no work around. The performances of the 2600 are just not adequate for fast ethernet, and it is also slowing down the file transfer
Get a bigger router or perhaps a L3 switch like an 8 ports 3560, that is very cost effective.
avilt Wed, 02/18/2009 - 16:56
My current router is running OSPF with 2 fa interfaces. I am not looking for a switch though, but can I use the above switch as router as well?
Correct Answer
Leo Laohoo Wed, 02/18/2009 - 17:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Leo Laohoo Wed, 02/18/2009 - 19:03
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
avilt Sun, 04/05/2009 - 21:42
I have some more queries.
1. How can I see the active traffic session on the router like netstat -n on windows?
2. I have set IP CEF on my router. Is it O.K? Do I need to configure ip route-cache {path} or Fast switching on any interface?
CPU utilization on my router goes high even when I transfer a 50MB file.
Joseph W. Doherty Mon, 04/06/2009 - 03:38
"CPU utilization on my router goes high even when I transfer a 50MB file."
Yes, that's to be expected! Reread Paolo's post.
For even a single FastEthernet interface, you need a much, much faster software router or a L3 switch. (The software routers are often most suitable for WAN bandwidths.)
PS:
#1 netflow cache or IP accounting stats might provide the information you want
#2 generally you always want CEF active, with it you don't need route-cache (CEF is even better than fast switching), however you might also activate flow cache
