ASA 5520 User Control
Feb 17th, 2009
Hi ,
Can we limit the number of users login to the VPN?
eg.
The group-policy A has 50 accounts configured in a Radius server. But we only allow 20 accounts/users login to the VPN concurrently.
Any way to achieve the above request?
Thanks & Regards,
eddie.mitchell@... Wed, 02/18/2009 - 06:18
  • Silver, 250 points or more
I believe this is the command you're looking for:
http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/uz.html#wp1563648')">http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/uz.html#wp1563648
This limits the number of IPSec sessions globally.
You can also use the following command to limit the number of concurrent logons per user account:
http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/uz.html#wp1563983')">http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/uz.html#wp1563983
Hope this helps.
doraemonheng Wed, 02/18/2009 - 17:36
Hi Eddie,
Thanks for your reply.
Seems like this command is for global configuration which will limit the entire box vpn session. What am looking for is to limit the session inside a particular group-policy. Anyway, this is a useful doc too ... thanks... : )
