MPLS configuration
Feb 17th, 2009
Hi pros,
I need to implement mpls for the isp here.
They bought some cat 6500 switches and cat 4500 switches.
Pls give the initial setps to enable mpls
Overall Rating: 5 (1 ratings)
guruprasadr Wed, 02/18/2009 - 01:25
HI Swami,
Please share the Target Plan that you wanted to implement.
Guru Prasad R
shivlu jain Wed, 02/18/2009 - 01:29
you can use the mpls ip and mpls label protocol ldp.
Every interface should be mpls ip and mpls label protocol ldp enabled
shivlu jain
Giuseppe Larosa Thu, 02/19/2009 - 08:42
Hello Swami,
this can be your reference
you need to use a classless routing protocol (OSPF or IS-IS to be preferred over EIGRP for possible MPLS TE future applications).
you need to advertise in the IGP the loopbacks addresses used to talk LDP over the MPLS enabled links.
MPLS needs to be enabled on all core facing links with
mpls ip
Take care of MTU issues: MPLS increase the size of frames and this needs to be handled on routers, multilayer switches and also on L2 only switches on the path.
for MPLS L3 VPN applications you will need also Multiprotocol BGP
Hope to help
